07-02-2024
10:01 AM
09:15 AM
James_C
I bought a Pixma TS3722 printer on 06/27/2024 and have beenunable to register it. When I put in my model TS3722, it says not found.
Any ideas?
07-02-2024
12:10 PM
08:56 AM
Hi festo04276,
Check out this link to make sure you're entering the correct serial number and if that doesn't work don't hesitate to reach out to our printer support team and they can help you get it registered, they can be reached at 800-652-2666 Monday-Friday
Hope this helps!
07-02-2024 06:19 PM
I was using the model #, so I tried the ser.# and got the same results.
07-02-2024 06:59 PM
When you search for a product to register, I recommend using the model #
I checked, Its there 😀
07-03-2024 02:58 PM
I called Canon support and was asked what country did it come from, and I said I assume the US, I said probebly China.they said it could be Canada. How am I suppose to know what country it came from. Regardless it is now registered.
07-10-2024 09:12 AM
I did not receive a solution . I had to call Canon, for them to tell me I had to use a canadian registration?????????
05-21-2025 05:12 AM
I found the FCC ID: AK=ZKD serial number, but received a notice that this printer cannot be registered in the US. Where can it be registered??
05-21-2025 05:15 AM
I just asked the same question. Are we supposed to move somewhere else just to register a product? I've had nothing but problems since I purchased this printer on 3/31/25. I should have stayed with HP.
