03-09-2025
10:11 PM
11:43 AM
I have been trying to print today and I get his message on my iPhone and iPad. The other day I did not have a problem printing. My iPhone is running the latest iOS and so is my iPad. Nothing has been changed router and printer. I get this message: security warning. The printer cannon ts3100 series appears to be a different printer than the previously used printer with the same name or the connection may not be trustworthy. If this is expected tap continue or cancel. I have reset printer several times and have restarted router once.
03-11-2025 09:17 AM
Thanks for joining the conversation, Raider2raven!
So that the Community can help you better, we need to know exactly which Canon printer model you're using within the PIXMA TS3100 series. The model number should appear on the top of the printer just above the on/off button. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
03-11-2025 11:42 AM
Cannon Pixma TS3122
03-11-2025 02:28 PM
Hi Raider2raven,
Please view "LotusPilot's" answer on Apple's Community board for his recommended solution to the message that you are experiencing. Please note, the printer is a different manufacturer, but the answer that LotusPilot provides should resolve this issue:
Why does my iPad show a security warning for printing? - Apple Community
03-11-2025 04:53 PM
I will try it out when i get a chance. From my understanding it sounds like I can just tap continue and it will do a new certificate. I don’t use a vpn so I don’t think I need to do the second pawr
03-12-2025 11:56 AM
Hi Raider2raven,
Yes, you can tap Continue and the message will stop until the printer is restarted.
