03-10-2025 10:44 AM
I would like to set the selection button not to beep when these are selected i.e to be silent
Please advise how to do this
03-12-2025 12:13 PM
Hi Flupsue,
Please try these steps:
1. With your PIXMA MX924 powered on, press the MENU button one time.
2. Press the down arrow 7 times. "Setup", with the screwdriver and wrench icon, should now be selected. If not, please use the arrow until it is.
3. Press OK.
4. Press the left arrow to select Device settings and press OK.
5. Use the down arrow to select Device user settings and press OK.
6. Use the down arrow to select Sound control and press OK.
7. Press OK on Keypad volume.
8. You can choose from Loud, Standard, Quiet or OFF. Once you have made you selection, press OK.
If you just chose OFF, the key beep will now be gone.
This information can be viewed in the manual as well. To access this, please use this link:
MX920 series > Overview of the Machine > Changing Settings on the LCD > Device user settings
03-12-2025 08:26 AM
Welcome to The Canon Community, and thank you for your inquiry!
We appreciate your participation, however, we need to let you know that the Canon Community is hosted and moderated within the United States by Canon USA. We are only able to provide support for Canon products manufactured for and used within the US market.
If you live outside the United States, please CLICK HERE and select your country or region for your support needs.
You're welcome to discuss Canon products sold outside of the United States, but please be aware that you will not receive support directly from Canon USA.
03-12-2025 12:13 PM
Hi Flupsue,
3. Press OK.
03-12-2025 01:05 PM
Thanks for the help
03-12-2025 01:56 PM
You're welcome!
