03-03-2026
06:45 PM
09:19 AM
I just recently changed my ink cartridges, as I always do, but for some reason, my printer canonTR8622 is printing blank pages or a few things very lightly. Please help!!!!!
03-04-2026 12:34 AM
If you installed the cartridges correctly you could have a bad cartridge or a clogged printer nozzle. I suggest you run the head cleaning function.
03-03-2026 08:29 PM - edited 03-03-2026 08:30 PM
In order to try and assist you, we will know the version and build of the operating system you are using the printer with? Also how it's connected and to what?
Canon Support for PIXMA TR8622 | Canon U.S.A., Inc. https://share.google/vJHeCZSnDq372EULC
03-04-2026 12:34 AM
03-04-2026 02:10 PM
Verify that you completely removed all the clear wrapper; there is a vent path that needs to be unobstructed. If that is not the problem then Derrick's recommendation should be followed. Run a nozzle check first.
