02-18-2023 06:42 PM - last edited on 02-21-2023 10:02 AM by Danny
Hello,
I recently purchased a pixma TR8620a printer. I am trying to scan some documents. How do I set it so that I can scan multiple pages into a single pdf?
Thanks,
Mike
02-21-2023 01:12 PM
You will want to download and install IJ scan Utility from the Canon website. This will allow you to scan multiple pages into 1 pdf file. Please click HERE to access the support page for your printer.
02-18-2023 06:52 PM
Welcome to the Canon forum!
So that the Community can help you better, we will need to know which operating system is running on your computer (i.e. Windows or macOS and which version). Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
Thank you!
02-18-2023 07:04 PM
It's a macOS
02-21-2023 01:12 PM
09-18-2023 03:01 PM
Having a similar issue with scanning multiple pages from the printer control panel and paten. I have followed the steps here and do not get the option to continue scanning. https://ij.manual.canon/ij/webmanual/Manual/All/TR8600%20series/EN/UG/ug-060.html
Using Mac OS Ventura, all drivers installed and up to date.
09-20-2023 11:29 AM
If you have the paper directly on the platen glass, try loading the paper in the automatic document feeder and then select the scan option.
09-20-2023 03:51 PM
I am scanning 2 sided documents so I need this to work on the platen if possible. Is there a way for this to work? My Provos canon (Maxify 2320) did this without an issue. I don’t understand what I’m messing with the pixma.
10-10-2023 01:30 AM
10-09-2023 11:33 PM
I would like to be able to use the platen to scan multiple pages into one document, using the operation panel, as I did for many years with my MX922. How is this done with the TR8620a?
10-10-2023 01:31 AM
found it, if you still need it: https://ij.manual.canon/ij/webmanual/Manual/All/TR8600%20series/EN/UG/ug-060.html
