On TS 3522 printer, there is no USB port at location shown on diagram
danmenkin
On my TS 3522 printer, there is no USB port at location shown on diagram (upper right corner when facing back), just an odd port sort of like a phone jack but with a plastic insert in middle, and the opening in the plastic case isn't big enough for a USB plug.  What to do?
      Thank you for any help you can offer.  --dab
jrhoffman75
Printer USB connection ports don't look like the USB ports you are used to. A printer USB cable has a square type connector on one end that connects to the printer.
3 REPLIES 3
jrhoffman75
THANK YOU so much, John.  I had no idea there were special printer-USB cables!  That solves my non-problem.   Bless you!
normadel
It's not a "special" printer USB cable. Printers and other peripherals, like scanners, external hard drives and more use good-old standard USB A-B cables.
