07-26-2024 11:03 AM
On my TS 3522 printer, there is no USB port at location shown on diagram (upper right corner when facing back), just an odd port sort of like a phone jack but with a plastic insert in middle, and the opening in the plastic case isn't big enough for a USB plug. What to do?
Thank you for any help you can offer. --dab
07-26-2024 11:48 AM - edited 07-26-2024 11:50 AM
Printer USB connection ports don't look like the USB ports you are used to. A printer USB cable has a square type connector on one end that connects to the printer.
07-26-2024 11:58 AM
THANK YOU so much, John. I had no idea there were special printer-USB cables! That solves my non-problem. Bless you!
07-27-2024 12:31 AM
It's not a "special" printer USB cable. Printers and other peripherals, like scanners, external hard drives and more use good-old standard USB A-B cables.
