11-09-2017 12:16 AM
After installing macOS 10.13.1 (High Sierra) MP Navigator EX 4.0 has ceased to work.
11-24-2017 04:14 PM
I tried Mr alvaromartinez's link, and MP Navigator installs, but it still won't open. As to using Image Capture with my CanoScan 9000F, it's fine for a simple scan of an item on the platen, but it gives me no navigation features to batch images into a single file, or to scan film or transparancies, or even to choose black and white over color, or image over document. This makes it more or less useless to me. I can photograph an image with my phone if all I need is a single page capture.
11-24-2017 05:03 PM
11-24-2017 05:58 PM
Groan. I deleted all the old files and now nothing comes up. I'm done. Right now, I have to restore my iPad, since the last IOS update screwed it up. I may never do another OS update!
11-26-2017 03:47 PM - edited 11-26-2017 03:49 PM
I've tried using Preview to scan as several here have suggested, but when I pull down the File menu, "Import from Scanner" is grayed out, ie unavailable. Do I need to add my peripheral somehow, so that Preview recognizes the device as a means of scanning?
11-28-2017 03:12 PM
I'm having a problem with my Canon LiDE 110 stand alone scanner. MP Navigator EX 4.0 stopped working AFTER I installed MacOS High Sierra. Before that worked fine. Any clues to get it to work or suggestions for new scanner software?
11-28-2017 03:19 PM
Attention everyone: the best solution to this upgrade-obsolescence problem that Canon has inflicted upon all of us is probably this:
Find an old laptop that's using a legacy version of MacOSX. Install MP Navigator and use it to operate your scanner.
I have done so, and now that I can use my laptop to scan with my MX350, I'll have to remember never to upgrade it.
None of the proposed workarounds -- neither using Preview, nor installing MP Navigator 4.0.5. -- have worked for me.
11-28-2017 03:50 PM
11-28-2017 04:37 PM
Had the same issue with PIXMA MG8120. The canon-asia update worked for me (I'm in USA). Thanks very much.
11-29-2017 02:02 PM
11-30-2017 02:29 AM
