Compatibility between macOS laptops and MP280, 9000F Mark II
NNG
I own a Canon scanner (CS-9000F Mark II Image Scanner) and printer (Pixma MP 280 series) which are both compatible with my old MacBook Air (OS 10.13.6/High Sierra).
However, they are not compatible with my other laptops (MacBook Pro — OS 26.0/Tahoe and MacBook Pro — OS 15.7/Sequoia). They date from 2025 and 2018 respectively.
I would like to know if there is anything I can do to establish compatibility with my laptops with their current operating systems.
If not, I would like to know what is the most recent MacBook operating system that the above two items are compatible with, presumably something between High Sierra and Sequoia. Once I know the answer to the second question, I may just take my 2018 MacBook Pro back to an older operating system.
Thank you
8 REPLIES 8
jrhoffman75
Thank you
If you go to the Canon support page for each printer you can select a macOS version and see if a driver is available. Keep going up till you get an OS that doesn’t list a driver.
Thanks, I will try that.
Arthur
Moderator
Moderator
Thanks for posting!
While our Forum Community members are welcome to chime in, the Canon PIXMA MP280 has been retired. That means we do not offer support for the printer or updated drivers. We recommend updating to a more modern printer and reaching out to our Canon Upgrade Program specialist who will go over the best options for upgrading your printer. They can be reached at 866-443-8002.
It's a printer and a scanner, both Canons, and I don't like tossing things into landfill when they are still in fine working order. So, I am trying to avoid that.
NNG
Further to the above query: I have followed Mr. Hoffman's advice.
For the Canon printer, I was offered the following six available and compatible software/driver options that, per the Canon site, will work with both of my MacBook Pros (one, OS V. 15.7 and another, OS V. 26.0). I have no idea which one (or more?) to choose. I don’t think I need all six!! Any advice?
1. File Name Easy-PhotoPrint Editor Ver.1.10.0 (Mac)
Type Software
Date 09.18.25
File Size418.72 MB
2. File Name MP280 series CUPS Printer Driver Ver.16.90.0.0 (Mac)
TypeDrivers
Date09.07.25
File Size14.88 MB
3. File Name ICA Driver Ver. 5.0.0 (Mac)
TypeDrivers
Date09.07.25
File Size8.64 MB
4. File Name Quick Menu Ver.2.8.2a (Mac)
TypeSoftware
Date09.07.25
File Size1.98 MB
5. File Name My Image Garden Ver.3.6.8 (Mac)
TypeSoftware
Date09.07.25
File Size300.21 MB
6. File Name MP Navigator EX Ver. 4.0.9 (Mac)
TypeSoftware
Date09.07.25
File Size31.89 MB
Hello, I followed your advice.
For the Canon printer, I was offered the following six available and compatible software/driver options that, per the Canon site, will work with both of my MacBook Pros (one, OS V. 15.7 and another, OS V. 26.0). I have no idea which one (or more?) to choose. Do you? I don’t think I need all six!! Thanks again.
Type Software
Date 09.18.25
File Size418.72 MB
TypeDrivers
Date09.07.25
File Size14.88 MB
TypeDrivers
Date09.07.25
File Size8.64 MB
TypeSoftware
Date09.07.25
File Size1.98 MB
TypeSoftware
Date09.07.25
File Size300.21 MB
TypeSoftware
Date09.07.25
File Size31.89 MB
rglaves
Posting the solution that worked to connect my Canon 9000F Mark II scanner with my M4 Macbook Air running Tahoe 26.5: downloading and installing the ICA Driver Ver. 5.0.0 (Mac). After doing that, the scanner (connected by USB) immediately showed up in the printers & scanners and Image Capture worked as normal. Other driver versions didn't work.
Wow, thanks for the input. I had given up on this ...  but now I will give your suggestion a try.
