12-21-2022 10:45 AM
I recently upgraded to Mac OS 13.1 (Ventura). After that, my printers disappeared. I used to be able to use it with OS printer/scanner utility. But now only the printer works. The scanner is not an option that shows up in Image Capture anymore.
So I downloaded the latest available software from Cannon:
MX490 series CUPS Printer Driver Ver. 16.70.0.0 (Mac)
IJ Scan Utility2 Ver.2.4.0 (Mac)
My Image Garden Ver.3.6.6 (Mac)
When I go to /Applications/Canon Utilities/IJ Scan Utility/Canon IJ Scan Utility2.app, I get
"A scanner driver supporting this software is not installed. Install it and try again. Code: 15,230,0"
What does this mean? How can I scan again?
12-21-2022 11:09 AM
It lIt looks like you might have failed to install the scanner driver as specified in the info for the scan utility.
12-21-2022 11:09 AM
12-21-2022 02:05 PM
That worked. Thanks @jrhoffman75
Silly me, I would've thought if a dependency was required for that software, it would've just come part of the same install process!.
07-03-2023 04:01 PM
I too am on Mac Ventura 13. My printer has been fine but has just stopped connecting. I get this message: "
The developer of this app needs to update it to work with this version of macOS. Contact the developer for more information."
I'm NOT really a computer tech so I'm lost! Help! Do I just go buy a new printer? Sally
07-03-2023 04:02 PM
PS It's impossible to contact the Developer!!!
