Getting error 7700 on my Pixma TR4722 while using Canon cartridges
RMerideth
Hi All,
Has anyone had the error 7700 on a Pixma while they are using new Canon cartridges?  What is the solution?
Rene
3 REPLIES 3
DerrickL
Understanding Error 7700 on Canon Pixma TR4722
Error 7700 on the Canon Pixma TR4722 typically indicates a problem with the printer's ink system. This error can arise due to various reasons, including issues with the ink cartridges or the printer's internal mechanisms.
Common Causes of Error 7700
  • Incompatible Cartridges: Ensure that you are using genuine Canon cartridges that are compatible with the TR4722 model.
  • Cartridge Installation: Check if the cartridges are installed correctly. Remove and reinsert them to ensure a proper connection.
  • Ink System Malfunction: There may be a malfunction within the printer's ink system that requires troubleshooting.
Troubleshooting Steps
  1. Check Cartridges: Verify that the cartridges are not expired and are properly seated in their slots.
  2. Reset the Printer: Turn off the printer, unplug it for a few minutes, then plug it back in and turn it on.
  3. Update Firmware: Ensure your printer's firmware is up to date, as updates can resolve various issues.
  4. Contact Support: If the error persists, consider reaching out to Canon support for further assistance.
RMerideth
Thanks for your help.  I have already done all of those steps and still nothing.   I think I've got a lemon, but I'll contact support directly.  It might just be a bad part or something.
DerrickL
I suspect a bad cartridge
