‎06-07-2023 06:19 PM
This is the first printer where I've had an issue setting automated double sided printing. I'm on Mac (Monterey) and the option is grayed out. How can I fix this? (If it's unfixable, that's a huge problem, we're back to the dark ages.)
‎06-09-2023 05:47 PM
Bumping. Can anyone help with this? I can't be the only person with this issue.
‎06-13-2023 01:12 PM
I was checking the manual and was able to see that you can print two sided from Windows but not MacOS. This is most likely due to Windows having drivers and with Mac having to use the built in Airprint.
You can check with Mac to see if they have a way to enable two sided printing from within the built in Airprint settings.
‎09-17-2023 10:53 PM
I am having the same issue. Answer below seems like it is not fixable.
Did you ever find a solution?
