01-16-2024
09:38 PM
09:41 PM
Mike
Just installed the print heads and filled the ink wells. When this was done the ink wells where full. Now the black
is alittle below half full. the color wells where full and now from left to right C half full, M and Y is below the first
line and they are going down very slowly. Don't know where the ink is going either.
01-23-2024 12:49 PM
If this was the first time setting it up, ink may have been used to prime the ink lines inside the printer. I suggest refilling the ink but if you notice the ink levels continue to drop at a fast rate, I recommend you reach out to Canon support.
You will need to register your Canon gear HERE to access additional support options.
