Canon Quick menu running at startup
wittrup
Every time I login this window pops up?
How can I remove this?
Running Win 10.
5 REPLIES 5
jrhoffman75
Open Quick menu, click the tool icon, uncheck start option.
Quick menu?
Where do I find the quick menu?
jrhoffman75
Doesn't your Post say Quick Menu is running at startup?
It should be showing on the Task Bar.
Well, sorry, indeed my post says "Quick menu".  I could not find a better name.  Disregard that terminology error.
After boot up, after login, on my Win 10 PC, the window in the original question pops up.
There is no canon related things showing on the Task bar.  Except for that window.  Nor any canon related in system tray.
Also, when entering Task Manager -> Startup (tab) I cannot see any canon related things there.
Nor any Canon related stuff in either:
C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup
C:\Users\wittrup\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
I have found a few canon related things in Registry.  However none that has lead me to any solutions.  As far as I can tell, it is some anyoing window that pops up as the driver is loaded during boot.  As I dig more and more into this problem, it seems Canon has provided me with some good grade bloatware...
It looks like WIA is a Microsoft Windows software.
https://msdn.microsoft.com/en-us/library/windows/desktop/ms630368(v=vs.85).aspx
Maybe if you look in Devices & Printers you will see a WIA scanner and you can disable/delete it.
