02-16-2015 03:22 PM
Hi all,
I have an issue with my printer. It's a Canon Pixma MG5500 Series. It used to be working fine up until a week or so ago when it started showing an error. I tried uninstalling and reinstalling everything, however it hasn't worked. The issue is that whenever I try to print, an error comes up on my laptop screen saying: Printer Not Responding. At times it has also said Printer is in Error State. Can someone please advise how to get my printer working again? Thanks.
10-26-2017 01:30 AM
I recently changed my internet provider and they gave me a new modem that comes with the router included.
I am experimenting the same "error state'
I used a windows 10 and I have a laptop Toshiba. What should I do, I have done everything you have mentioned here, I dont know what else to do?? I put the printer closer to the access, put again the wifi password, turned it on and off several times.
I used the printer wireless so I dont have a cord.
thank you,
10-26-2017 08:55 AM
Hi lauracardenas58!
Thanks for reaching out to Canon USA, we're happy to help!
You'll want to head to http://www.usa.canon.com/wirelesshelp
Once you're there, enter your printer model number and then select the option called "Re-establishing Printer Connection After A Network Change." It will bring up step-by-step instructions for changing your network information.
If you find you need one-on-one, live help, our US-based team is available weekdays from 10am to 10pm (ET), and support at Canon USA is always free!
11-20-2017 01:37 AM
Not sure you will read this, but maybe someone looking for an answer will.
I had the same issue and fiddled my way to a solution.
For some reason I have to select Canon mg2500 (copy 1), beneath "select printer" in the system dialogue window (CTRL + SHIFT + P) and not canon mg2500
11-20-2017 01:38 AM
04-28-2018 12:40 AM
so please tellus how the hell to fix the "printer in state of error" so I can print again
11-26-2018 07:39 AM
i have this same problem, did you ever fix it??
04-24-2019 06:11 PM
04-24-2019 06:11 PM
