01-26-2015 04:39 PM
01-29-2015 07:39 AM
Hi Creede,
Since you have already verified that there are no jams or obstructions in the printer, performing a roller cleaning may resolve the issue. To do this, please turn off the printer, unplug the power cord from the back and leave it out for at least 10 minutes, then plug it back in and turn it back on. Next, please follow the steps located here to perform a roller cleaning.
If you still experience the same issue after performing the roller cleaning at least three times, or if you are unable to perform the roller cleaning due the error, cleaning the timing encoder strip of the printer may resolve the issue. To do this, please follow the steps located here.
Should you continue to experience difficulty, the printer may require servicing; please call or email us at one of the methods on the Contact Us page for further assistance.
12-05-2015 09:16 AM
I began receiving paper jam messages several days ago. There is absolutely no paper jammed anywhere nor any obstructions. The printer will not allow me to perform any of the suggested steps DUE TO THE 1311 CODE! (Ie roller cleaning, tape cleaning, etc.)
HELP!!!! My 6320 has been perfectly satisfactory (it's less than 2 years old) until this sudden notice.
12-09-2015 08:50 AM
Hello.
If you continue to have difficulties and no obstructions can be found, contact our support group by using the "Contact Us" link below.
02-15-2016 03:01 PM
I have done this, but it did not solve the problem. New paper jams first time through. I thinkt here is still something inside, but in this model it is not possible to see all of the paper path. I need instructions how to open it to properly to clear the whole paper path.
