Canon MG6821 Error No Paper Can I clean the rollers?
MapJfl
I've had my printer for a number of years and recently it won't feed the paper to print and I'm getting a No Paper error or if I manually feed the paper it jams.  Is there any way to clean the rollers that feed the paper to print?
1 REPLY 1
DerrickL
Whiz
Whiz
Cleaning the Paper Feed Roller on Canon MG6821
Steps to Clean the Roller
To effectively clean the paper feed roller on your Canon MG6821, follow these steps:
  1. Access Maintenance Screen
    • Turn on your printer.
    • Navigate to the Maintenance screen.
  2. Select Roller Cleaning
    • Tap on "Roller cleaning."
    • A confirmation screen will appear.
  3. Prepare for Cleaning
    • Remove any paper from the cassette.
    • Load three sheets of A4 or Letter-sized plain paper into the cassette.
  4. Start the Cleaning Process
    • Open the paper output tray gently.
    • The cleaning process will begin automatically.
  5. Completion
    • Wait for the paper to be ejected.
    • When the completion message appears, tap "OK."
Important Notes
  • Cleaning the roller should only be done when necessary, as it may wear out the roller over time.
  • If the issue persists after cleaning, consider contacting a service center for further assistance.
