01-30-2026
03:49 PM
10:05 AM
James_C
01-30-2026 03:54 PM
Welcome to the forum!
So that the Community can help you better, let us know how are you connecting? Which version of Windows or macOS you are using? What is the exact error message? Any other details you'd like to give will only help the Community better understand your issue. The forum is not intended for immediate support. If this is a time-sensitive matter, click HERE search our knowledge base or find additional support options HERE
01-31-2026 06:33 AM
In addition to the information Tiffany requested, do documents other than PDFs print?
01-31-2026 11:28 AM
I am using windows 11. There are no error messages, the printer does nothing. Also, I can print other things, like emails. Thank you for your help.
01-31-2026 11:29 AM
Yes, like email with no problem.
01-31-2026 12:00 PM
https://easytechsolver.com/why-wont-my-printer-print-a-pdf/
02-01-2026 10:33 AM
Thank you.
02-01-2026 12:14 PM
How is your printer connected, and to what?
USB, Wi-Fi, etc?
Did you install drivers for your printer from its support portal?
Canon Support for PIXMA TR7020a | Canon U.S.A., Inc. https://share.google/6hmd8asF14XPjFU7k
02-07-2026 10:12 AM
It is connected via wifi. Yes, I downloaded and installed driver, but still have the problem.
02-08-2026 06:19 PM - edited 02-08-2026 06:22 PM
You may have tried many of these "fixes" but it is the best I can tell you:
Driver Issues: Ensure that you have the latest printer drivers installed. Outdated or corrupted drivers can prevent printing.
PDF File Corruption: The PDF file itself may be corrupted. Try printing a different PDF to see if the issue persists.
Software Conflicts: Sometimes, the PDF viewer software can cause issues. Try using a different PDF reader, such as Adobe Acrobat Reader or another application.
Update Printer Drivers:
Check Printer Settings:
Test with Different Files:
Restart Devices:
Check Printer Queue:
Use a USB Connection: If you are using a wireless connection, try connecting the printer directly to your computer with a USB cable to see if that resolves the issue.
Reinstall PDF Software: If the problem continues, consider reinstalling the PDF viewer software you are using.
As a work-a-round you can convert your PDF to a Word document here:
