01-20-2026
06:58 PM
08:22 AM
James_C
Running Mac os Tahoe 26.2 have loaded the latest canon drivers and print utility. G3270 Scanner is not listed anywhere. When I open the scanner tool, the only scanner is a printer that has been remvoed. When opening Image Scan, no devices are listed.
i can scan from my iphone.
01-20-2026 07:36 PM - edited 01-20-2026 07:38 PM
To install the Canon G3270 on macOS Tahoe 26.2, download the appropriate drivers from the Canon website, then connect the printer via USB and follow the setup instructions to add the printer in your Mac's "Printers & Scanners" settings. Make sure to restart both the printer and your Mac if you encounter any issues during the installation.
Drivers and software:
https://www.usa.canon.com/support/p/pixma-g3270
Installing Canon G3270 on macOS Tahoe 26.2
02-04-2026 03:15 AM
i have done that many times…. still NO SCANNER..
02-04-2026 03:19 AM
if you had read my post, I have the printer installed. the Scanner is not visible anywhere.
02-04-2026 10:25 AM
For our benefit, does this mean you had installed the IJ Scanner lite utility v4.2.0 also?
Sometimes when you re-install drivers over a failed printer instance things can go wrong, do not get fixed or resolved.
How is the printer connected and to what? Wi-Fi, USB, etc?
We'll await your reply.
02-04-2026 09:43 PM
Yes I have installed both the Master setup and the Scanner lite utility. Several times…. all the scanner utility shows is a previous (uninstalled) printer. when searching, it does not find the new printer/scanner
02-05-2026 09:52 AM - edited 02-05-2026 09:54 AM
If the IJScanner lite is finding an old printer/scanner then it is obviously not uninstalled. If you follow the steps below you will need to reinstall the software for your G3270, however you should have better results this time.
To completely uninstall a printer or scanner from your Mac running macOS Tahoe 26.2, follow these steps:
If you want to remove all printers and reset the printing system:
To ensure all associated files are removed:
/Library/Printers and press Enter.After completing these steps, restart your Mac to ensure all changes take effect.
Following these steps will help you completely uninstall a printer or scanner from your Mac.
02-05-2026 08:42 PM
i have already deleted the old printer. only printer listed in the printer list is the new printer. When going to the /library/printers folder, there is NO printer listed.
02-06-2026 03:24 AM
i have installed the master setup and the scanner utility MANY TIMES...
02-08-2026 07:26 AM
i keep trying to download drivers for G3270, but what is coming down is 3070 series. how do i get the specific driver for G3270?
