Pixma MG6150 printer spring
I've taken my printer apart to clean the ink absorber pads. This spring has fallen out from somewhere. Any idea where from?
The message you are trying to access is permanently deleted.
Where is the macOS Tahoe V26 Driver TR8620a? See Screen Capture.
Do empty print cartridges have to be returned under the Pixna Print Plan, or do I just dispose of them?ThanksJohn Bowen
Hey, I just got a Pixma Canon iX6820 and the ink carriage won't move left to right. When I turn it on there is a loud clicking noise as the carriage tries to move a little but it seems stuck. I was able to print one time until this happened and it wa...
Please help. I waited 2 month for this printer and finally got it. When I was setting it up and I got to step 3 I pressed the power button and got a flashing orange light. The ink cartridge sounds like its trying to move but is stuck or grinding. I h...
My computer: M2 Mac MiniMy internet speed: 1000 mbpsI have restarted the computer, printer snd router multiple times, but the printer continues to print at a snail's pace. I tried sending a Word document (no color) with one sentence. It took 15 min...
When clicking the IJ Printer Assistant tool icon, I get the message: A printer that supports the IJ printer assistant tool cannot be found. Also, what is the purpose of the Canon Print Assistant. It just has some notes on usage. Thank you.
Hi - I'm hoping there's a simple (& fixable!) reason why our #MG5750 should have suddenly, between print jobs (5mins after the last perfectly OK one), started printing blank sheets. No gradual fading of colours, no one colour missing, all others OK, ...
Will Canon be updating the software for the Pixma MX532 to be compatible with MacOS 27 Golden Gate? If the do not is the only alternative to buy a new printer to replace the perfectly good Canon printer I have now?
hello,My canon Pixma 2522 printer is connected to my computer via USB cable. It shows up fine and when I click for it to print a job, the machine grabs the paper as if it is going to begin the print job but immediately stop right after that, it will ...
I just got a new PIXMA TS4320 last month - then I moved. Now I need to change the network name and password. I've tried everything I know to do, the app just connects me to a temporary network(?) and then says to do it on the printer, but the printer...
Win 11 wi-fi, no errors, print head removed and cleaned, replaced cartridges, etc etc and as I said my printout looks exactly like API posted above. Wavy lines through the middle of the black grid. The workaround suggested by someone is to print your...
Ordered from Staples. This is a basic unit...no auto feed, etc. I was apprehensive about setting it up compared to Brand X in the past. Very simple, just follow the instructions and move to the next step. Print sample came out great. Scanned a sheet ...
My Canon TS3722 was working fine, until just a few days ago. Nothing had changed. It started showing OFFLINE. I reinstalled the driver and now it is only showing as a scanner, no longer as a printer. Can anyone help? Thanks in advance. Sparkie
My print has just now been ripped apart from it's guts. It is the worst printer I've ever used in since printers came out for home use. I spent so much money replacing paper and ink and my time fixing and fixing and ever ending fixing. It's now a pil...
| Subject | Author | Posted |
| 07-07-2026 07:06 PM | ||
| 02-03-2026 03:40 PM | ||
| 01-29-2026 08:25 AM | ||
| 12-27-2025 03:38 PM | ||
| 10-06-2025 05:10 PM |
