Strange Results Editing .CRW Files In DPP4
BurnUnit
Whiz
Whiz
Here's a strange phenomenon that I somehow uncovered in DPP4 (V4.17.10.0) while editing some .CRW raw files from an old Canon Digital Rebel.
After making some adjustments (which are somewhat limited compared to what I can do with .CR2 files) I did a Batch Process to a group of shots to convert to .JPGs and save. No hiccups there as best as I can recall. But a few days later when reviewing the .JPGs this one, single, odd image in the batch showed up. In some areas that appeared overexposed, the blown-out highlights displayed as solid black in the JPGs, the same as seen in this first screen-shot of my saved .CRW file
I can't imagine missing that while editing the raw images, but maybe I dozed off for a few seconds. Or I got distracted when the phone rang. Or more likely, I pasted a recipe from a previous file and for some reason it took longer than normal for the adjustments to show up onscreen.
So I opened the .CRW file with the saved changes in DPP4 again and with the Highlights/Shadows warning enabled, this is what I see. Which wasn't all that surprising to me except for the fact that I didn't see it this way while doing the original editing. Also, what are obviously blown Highlights are displayed in blue instead of red because the adjustments I made rendered them as black, as shown in this second screen-shot.
In this final screenshot I disabled the Highlights/Shadows warning and backed down the Highlight slider to -5.0 from +1.0 and what do you know? The previously black highlight areas disappeared and I started to pull up at least a tiny bit more detail in the highlights. Saved my raw edits and converted to a .JPG again and the results look just like the re-edited .CRW this time.
What I'm figuring is that all this strange behavior is probably due to operator error on my part. But just in case, I'm curious if there might be some other distinct differences between .CRW and .CR2 files that I'm not aware of. Maybe something in the areas of dynamic range or sensor designs or in-camera processor types. I know I wasn't doing myself any favors by starting off with an overexposed image. But does it mean that this Digital Rebel is showing its age by "misbehaving" in a more evil, permanent way? Everything else about it seems to still be working properly, though I have no intentions of using it as a substitute for my 60D.
13 REPLIES 13
@BurnUnit wrote:
Yep. It just looks like the Rebel/300D doesn't support any lens I.D. in the EXIF data. Though it reports the focal length and aperture that was used. The only other CRW files I've worked with were from a G5 which used a fixed lens.
Now if I can only figure out how to register my name into the Rebel's EXIF info . . .
Thanks for lending a hand!
You might be able to do it using Logipole Software Metadata ++
wq9nsc
I have noticed a color shift to bluish tinge in clipped areas when working in DPP with some files from my 1DX II and III bodies; it seems to be a weird issue that sometimes shows up in DPP with highly clipped RAW images.
I recently shot some photos in a fairly dim church and partway through the ceremony the priest, wearing beautiful white vestments, stepped into a beam of light coming through a skylight.  I adjusted settings quickly to reduce the clipping issue and had to really bring up the shadows for the other participants to show.  With the initial exposure settings he could be best described as looking like a smurf from another planet in the initial RAW conversion using DPP 🙂
Rodger
EosUtility or Gphoto2 (Linux/OS X) should be able to change your owner name. I have changed owner name in the older camera D30.
I think Canon dropped ZoomBrowser in favor of ImageBrowser EX. They don't show downloads for either available for Win10. Any EOS Utilities listed doesn't show compatibility with the Digital Rebel, though they mostly seem to cover things like WiFi connectivity and live video streaming for much newer models. I think I'm just trying jump too much of a gap between the Rebel and Win10.
I did somewhat get some versions of ZB ex and EOS Utility to install from the Canon CD that shipped with my 60D, but just about all the button are non-responsive or they won't recognize the old Rebel when connected. Nor will they allow me to upgrade them.
I'll look into Logipole a bit more. But what I've seen so far indicates to me that it adds EXIF data to your files after they're DL'd to your desktop. Mostly what I was hoping to do was tattoo my mane into the camera's memory.
If I decide to pursue this further at a later time I'll start a new thread here if I find myself in another jam.
