new to me gimp3
johnrmoyer
Whiz
Whiz
I have downloaded Gimp version 3 for macOS.
One thing that I like is the GEGL operation DCT noise reduction.
https://docs.gimp.org/3.0/en/gimp-filter-noise-reduction.html
This is a split screen of an ISO 16000 photo from an EOS R5. I saved a 16 bit TIFF from DPP and loaded it into gimp. I used a 16x16 patch instead of the default 8x8 and that caused it to take a very long time to run on a 8000x5333 image. This is a crop from a photo of a Fox Squirrel (Sciurus niger) in Norman, Oklahoma, United States on May 29, 2025 and a screen capture of the eye during editing in Gimp 3. In Canon DPP I set the noise reduction to 1.0 before saving it and loading it into gimp.
One other new feature of Gimp is that it uses the jpegxl library which has the improved JPEG compression from https://arxiv.org/html/2403.18589v1 . This results in much smaller files. It would be good if the next version of Canon DPP could also use this technique.
JPEG quality of 75 in Gimp 3 to make file small enough to upload.JPEG quality of 75 in Gimp 3 to make file small enough to upload.
File:Other FileName IMG_3666c.JPG
EXIF:Image ISO 16000
Composite:Image ShutterSpeed 1/400
EXIF:Image LensModel EF100-400mm f/4.5-5.6L IS II USM +1.4x III
EXIF:Image FNumber 11.0
1 REPLY 1
Greetings ,
Product enhancements and feature requests can be made on the Canon USA homepage. Choose [+]Feedback then product and leave your request. The link is in the top right hand corner or bottom center of the page.
