How to change the shot date in ImageBrowser?
TheDobsonGuy
My Slidescanner defaults to the same date.  How do I use imagebrowser to reset the shot date to a date I specify?
Mykolas
Hi TheDobsonGuy!
Thanks for posting.
The shooting date/time is part of the EXIF information embedded with each image by the camera as it was taken.  ImageBrowser does not have a tool that allows the EXIF information to be edited.
However, if you find the actual image file on your computer, using WIndows File Explorer for example, you can right-click on the image and display its properties.  You can try adjusting the shooting date that way.
3 REPLIES 3
Mykolas
Hi TheDobsonGuy!
Thanks for posting.
@inactive010823 wrote:
Hi TheDobsonGuy!
Thanks for posting.
I wouldn't try that. My experience has been that the metadata you can set with the Windows tool step on a Canon RAW file's Exif data in unpredictable, and irreversible, ways. If you're going to play around with it, be sure your backups are in order first.
Bob
Thanks for the warning:  I've a lot of scanned slides to  jpgs that I need to reset the shot date -- lightroom, and others can do this in a batch.
Cheers!
