Folders Unavailable in DPP
Schroed
Just starting to use DPP for RAW conversion from R5 based on comments that it is better than Adobe apps.  However, when I open DPP on my iMac, I can't access several folders, including Desktop.  The folder names in the left column have a very small white circle with a down arrow in it.  See attached screen shot. Screen Shot 2021-05-05 at 5.17.19 PM.png
This probably reflects some setting I have wrong, but I can't find any reference to this.  Any suggestions?
Thanks.
jrhoffman75
Are those foldrs in iCloud and need to be downloaded?
Have you granted folder access to DPP in the Privacy section?
4 REPLIES 4
Waddizzle
Ask Apple what it means.  I don't think Canon makes Macs or their OS.
jrhoffman75
Bingo!  Thank you John.  The privacy settings did the trick.
I suspect that you would be better off over the long run by creating a separate folder just for DPP images.
[EDIT] I would also restore the previous access level that denied DPP access to the private folder.
