12-06-2022
07:25 PM
08:42 AM
Hello,
I have been breaking my head since last wekeend as EOS Utility is not working properly on Ventura MACOS, But all begun because my videos were "missing" on my external disk where I download images/videos from my camera.
Turns out videos are being downloaded but they are stored as "hidden files" on my external disk, I have to press a few keys each time I want to "reveal" those files. Only videos are hidden, JPEG and RAW photos show normally.
Does someone know why is this happening and how can it be solved?
Google shows me completely unrelated info when searching for hidden files on macos.
Help would be greatly apreciated.
12-07-2022 12:41 PM
Don't know why I didn't think of this yesterday, but to unhide all files with the same extension at once, do the following:
Or, enter in /*.MOV
i.e. whatever your video file extensions are.
Example full command (I have a "Canon" folder on my external "Scratch" volume):
chflags nohidden /Volumes/Scratch/Canon/*.MP4
12-06-2022 08:17 PM
That definitely sounds like a bug in Canon's utility (changing the file's metadata to have it be hidden).
Hmm... having written that, I do wonder now if the files were even correctly copied over. I'm thinking that the software may be starting to copy the video files (and setting them as hidden), then once the copy is complete, it will unhide them.
When you use Command-Shift-. to temporarily unhide them, do any of the video filenames start with a period?
If they start with a period, they will always be hidden. But hopefully they don't have such filenames. You can then perform the following (note that I don't know yet how to unhide every hidden file at once within a folder)
12-07-2022 12:32 PM
Thank you for your help.
Name files shows correctly after unhidding them. I'll try your steps but I see they have to be made file per file.
I´ll try to get hold of a windows computer to download the files in the future. =(
12-07-2022 12:41 PM
Or, enter in /*.MOV
01-03-2023 04:26 PM - edited 01-03-2023 06:13 PM
Thank you, yes I can unhide all the videos on a single folder.
Hopefully they fix the EOS Utility app soon as it still hides all the videos I transfer and have to manually unhide them.
01-20-2024 08:11 AM
Its not working for me for some reason.
this what it gives me when i type in the prompt
"zsh: no matches found: /*.MP4"
01-20-2024 08:14 AM
Did you find the location (folder) to search and drag that in Terminal?
Or, you can manually type in the command along with the path as I showed in the example in the solution.
01-20-2024 08:18 AM
yes i did.
I typed: chflags nohidden /Volumes/BackupDrive/Pictures /*.MP4
01-20-2024 08:56 AM
If it fails to find any files, then there are either no MPEG-4 files there (with extension .MP4), or you don't have the correct permissions to view the contents of that folder.
What happens if, in Terminal, you navigate to /Volumes/BackupDrive/Pictures/ and then do:
ls -alF
Do you see any .MP4 files listed in there?
Note also that this command wouldn't recursively process files in nested folders. To do so, add in a "-R", but be careful when doing that. e.g. to change the hidden properties of any .MP4 files in the main folder provided as well as all its subfolders:
chflags -R nohidden /Volumes/BackupDrive/Pictures /*.MP4
01-20-2024 09:21 AM
It worked.
I removed (*) from the written command and it worked.
Many thanks.
