EOS Utility 3 file saving to camera
Anomaly
I am using EOS Utility 3 for live view on the computer and remote shutter release.  I would like to know if there is a way to save the images to the camera rather than the computer with EOS Utility 3, as I have been unable to do so.
2 ACCEPTED SOLUTIONS
I've solved this before, but couldn't remember how. I just know that my shots always stay on camera. So, I dug around a little tonight and found the solution, and, although it's in plain sight, it's still illusive. Just click the little camera with the down arrow beside it (see attached image), and there ya go.
Newton
Thanks FloridaDrafter, you made my day!  I should have noticed that but my old eyes aren't what they used to be.
9 REPLIES 9
stevet1
Anomaly,
A Google search yielded this result:
"You can save the images taken both on the computer and on a memory card by shooting this way. To make this setting, click [Preferences] on the main window of EOS Utility to display the [Preferences] dialog box. Click the [Remote Shooting] tab, and then check [Save also on the camera's memory card]"
Steve Thomas.
Anomaly
stevet1,
I want to save only on the memory card and not both the computer and the memory card.  I don't see how to do this.
The problem is that I am trying to trigger the shutter up to 100 times at a rate of 1 trigger/sec.  Downloading to the computer is a bottleneck and causes the process to stop before all images are taken.  I suspect that saving the images only to the memory card would be faster.
Thanks,
Anomaly
Waddizzle
Slow USB connection?
What camera are you using?  What type of USB port on the computer?
Anomaly
The camera is an R7 and the port is USB 3.0.
The problem may be a combination of camera buffering and download speed.  I am going to experiment with taking EOS Utility 3 out of the setup and seeing if the camera can save the images to only the memory card before the buffering cuts off accepting external triggers.
Newton
You are welcome. As for not noticing it, I've done it before and still missed it 🙂
Grazie!
@Nicklite wrote:
Grazie!
Prego!
Newton
Holiday
EOS C400 - Version 1.0.4.1
EOS C80 - Version 1.0.4.1
XF605 - Version 1.0.7.1
EOS R3 - Version 2.0.0
EOS R1 - Version 1.2.0
EOS R5 - Version 2.2.1
EOS R7 - Version 1.7.1
EOS R10 - Version 1.7.0
EOS R8 - Version 1.5.0
EOS R50 - Version 1.4.0
Powershot V10 - Version 1.4.0
Powershot V1 - Version 1.1.0
EOS R50V - Version 1.1.1
