08-29-2023
08:09 AM
08:18 AM
I've downloaded the firmware but it only shows on my Mac as a .dmg file. When I click on it, it does not open further. Is this whole .dmg file what I drag to my card?
Thanks. I obviously don't want to screw this up!
08-29-2023 09:12 AM
Thanks for all the responses, but it appears the problem is with Canon. I was able to successfully open other .dmg files from the Canon website, just not the firmware (Yes, I had the right OS selected).
I had Apple tech doing the same thing remotely on his computer and he had exactly the same problem with the firmware file.
Perhaps if Canon is monitoring this thread they can look into it.
08-29-2023 09:20 AM
I would recommend downloading again. I just downloaded the 1.0.2 DMG and it opened up a-ok on my Mac. Shows up as a volume named "eos6d2-v120-mac".
From Terminal, if executing the md5 command on the eos6d2-v120-mac.dmg file, it displays:
4f38ef57942d3f287c8ab9660f36aced
If you do the same from Terminal and see a different value, then somehow that file is getting mangled along the way to your computer.
08-29-2023 09:25 AM
Thanks, but I stay out of Terminal and nuclear power plant control rooms. I've downloaded it three times and the Apple tech downloaded it twice. Other .dmg files open, just not this one. Even if I did go into Terminal and find a different value on the file, it does not fix the issue. I hope Canon will monitor this and look into it.
08-29-2023 09:29 AM
As in the case of Ricky and Stephen the firmware file is opening / mounting for me as well. I'm using Ventura. .FIR file and instructions are present. Working as expected.
08-29-2023 09:32 AM
Well, I dunno... I open .dmg files all the time without problem, and even opened other .dmg files on the Canon website. The Apple tech also was unable to open the firmware file.
Hmmm, I wonder if someone can send the their .fir version of the file?
08-29-2023 09:36 AM
But there wouldn't be anything for Canon to do. By checking the MD5 digest, you'd know for sure if the file was somehow being modified along to the way to your Mac. Not sure what that would be though; perhaps something with your internet provider?
Or, do you have a virus checker that you have installed that is perhaps incorrectly flagging this particular DMG and then modifying it?
If you really want to avoid Terminal, do at least check the file size of the downloaded DMG (Command-I or Get Info from Finder). For my downloaded copy, it shows a size of: 38,020,608 bytes.
08-29-2023 09:37 AM
I downloaded the file when you said you were having problems earlier.
This is my system:M1 Mac Mini 8GB RAM macOS Sonoma 14 Beta
Again, when you download the DMG, it will go into your Downloads folder:
Double-click it, and it will mount (it will just look like it flashes). It will then be either in Finder - on the left Nav Bar under Locations:
OR on your Desktop:
Once you've located the icon for the Disk Image, double click it and open it. You'll see the .FIR file, and a folder with PDF instructions:
Simply drag the .FIR file onto your SD card (in a card reader is the easiest way), and you're good to go!
I hope this helps, but if you need one-on-one assistance, don't hesitate to contact phone support at 800-OK-CANON (800-652-2666). They'll be happy to walk you through it!
08-29-2023 09:39 AM
The file that I and the Apple tech are downloading is:
eos6d2-v120.mac.dmg
08-29-2023 09:42 AM
Thanks for hanging in on this, but I went through all the virus-blocking culprits. The file size is 38M, as it should be. It doesn't explain how the Apple tech had exactly the same problem on his computer. I have no problems with other .dmg files, including two others on from the Canon site.
08-29-2023 09:45 AM
The file should be eos6d2-v120-mac.dmg not .mac.dmg. Are you sure you're downloading the file from the Canon USA website: https://www.usa.canon.com/support/p/eos-6d-mark-ii#idReference%3Dsoftware-drivers
