08-29-2023
08:09 AM
08:18 AM
I've downloaded the firmware but it only shows on my Mac as a .dmg file. When I click on it, it does not open further. Is this whole .dmg file what I drag to my card?
Thanks. I obviously don't want to screw this up!
08-29-2023 09:37 AM
I downloaded the file when you said you were having problems earlier.
This is my system:M1 Mac Mini 8GB RAM macOS Sonoma 14 Beta
Again, when you download the DMG, it will go into your Downloads folder:
Double-click it, and it will mount (it will just look like it flashes). It will then be either in Finder - on the left Nav Bar under Locations:
OR on your Desktop:
Once you've located the icon for the Disk Image, double click it and open it. You'll see the .FIR file, and a folder with PDF instructions:
Simply drag the .FIR file onto your SD card (in a card reader is the easiest way), and you're good to go!
I hope this helps, but if you need one-on-one assistance, don't hesitate to contact phone support at 800-OK-CANON (800-652-2666). They'll be happy to walk you through it!
08-29-2023 08:11 AM
Thanks for joining the conversation, Skip70!
So that the Community can help you better, we need to know exactly which Canon camera model you're using and which firmware version you're trying to install. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
08-29-2023 08:14 AM
Sorry.
6D Mark II. I went on firmware site and 1.2.0 is what came up. I assume that is the latest.
08-29-2023 08:19 AM
A "dmg" is a Disk iMaGe. When you double-click it, it should reveal an item on your desktop within Finder. If not, when in Finder, access the Finder menu, then select Settings (Note: may be Preferences on older operating systems).
When the Finder Settings/Preferences window displays, select the "General" icon, and ensure you have the following items checked:
[X] Hard disks
[X] External disks
[X] CDs, DVDs, and iPods
When you find the item on your desktop, it should contain the instructions along with the firmware file. Typically, you need to copy just the firmware file itself to an SD card. But review the instructions for exact details.
08-29-2023 08:25 AM
Yes, those were all checked, still does not open. Next call: Mac Support!
08-29-2023 08:30 AM
If you've double-clicked on the .dmg and are still not seeing anything, launch the Disk Utility application. I can be found in the Utilities folder within your Applications folder. Or, type in Command-Space and type in Disk Utility followed by Return/Enter to launch it.
In the Disk Utility window, it should list all the disks currently connected to your Mac. You can also use the File menu, then Open Disk Image... option within Disk Utility to open a disk image.
08-29-2023 08:32 AM - edited 08-29-2023 08:34 AM
(Not tech support, but I am 100% Apple) - the DMG needs to be on your Mac - either in your Downloads Folder, or on your Desktop - not on the SD card. Double click the DMG file, and it will Mount (it only looks like it flashes - but nothing "happens"). From there - on your DESKTOP, you'll see a drive icon that says "eos6d2 [something" - double click that. You'll see the .FIR file, and a folder with 5 PDF files - one is English (en).
Drag the .FIR file to the ROOT of your SD card (not in any folder - just drop it into the card)
Let me know if you need screenshots! 😊
08-29-2023 08:36 AM
Thanks again for the detailed alternate. Still does not open, so on phone with Apple now. I've never had problems in the past opening .dmg files.
08-29-2023 08:42 AM
Do you have any other .dmg files you can try? Perhaps the one you've downloaded is incomplete or has become corrupted. Though that should have generated an error message within Disk Utility.
08-29-2023 09:09 AM
Yes, of course, I'm on the Mac. It does not open. Other dmg files do open, just not this one.
