08-26-2022 09:32 PM
For many years Photoshop has been the go to editing software for many people, amateur and professional alike. Now there are several equally high quality editors available. I would suggest that the Transfer to Photoshop option be modified to allow the user to pick the photo software they use for editing.
08-27-2022 06:44 AM
I believe that feature is already available using the EOS Utility when you download files via USB. There is an option to select which editor you want to launch after the photos are downloaded.
08-27-2022 08:48 AM
@Daltongang wrote:For many years Photoshop has been the go to editing software for many people, amateur and professional alike. Now there are several equally high quality editors available. I would suggest that the Transfer to Photoshop option be modified to allow the user to pick the photo software they use for editing.
Since you mentioned DPP I am assuming you do some initial editing in DPP and want to do additional work in an alternate software.
You can achieve that by using the Batch tool in DPP. (A "batch" could be just one image).
08-28-2022 02:52 AM
That's pretty cool! Has that always been there?
Newton
08-28-2022 07:08 AM
Hi Newton. Yes, back into early versions of DPP3 at least.
08-28-2022 07:36 AM
Batch processing is one of the things DPP does very well and this runs as a semi-independent process so you can do other activities in DPP while batch is doing its thing.
I use 1DX series bodies for sports events but sometimes I will also bring a pair of 5DS-R bodies along for non-action photos and after I edit and the 1DX photos are batching, I edit the 5DS photos which I keep in a separate directory structure. On a robust PC, running batch plus editing doesn't seem to slow either process much.
Rodger
08-28-2022 11:43 AM
Thanks, What you're suggesting does work, but in a backwards sort of way. I'm not looking to create a new file, just continue working on the current file in a program (Capture One) other than Photoshop that also handles RAW files. If memory serves me correctly, the Transfer to Photoshop option does not create a new file but transfers the photo directly to Photoshop.
08-28-2022 01:29 PM
You are correct that the file is not saved, but a new TIFF file is created.
08-28-2022 02:49 PM
That's getting closer, but it would still be nice to directly open a raw file from DPP4 in another editor. I know it is possible, my DAM program does it seamlessly.
08-28-2022 02:58 PM
Only surmising since I don’t work for Canon, but DPP4 is program for editing Canon files. It isn’t intended to be a filing and asset management software. The only way for a user to take advantage of the in-camera and/or DPP4 settings like Picture Style, ALO and lens corrections is to render the RAW file.
