10-16-2016 05:43 PM
Just discovered that the Canon RAW files shot with a Canon 20D in 2005, are no longer openable. (is that a word?) I have a few thousand of them and in '05, '06, etc., i opened them, worked on them in PS and saved them. Now i want to work with some of them and they are not viewable, openable, etc. Not with Canon software, Adobe DNG Converter, etc.. I don't know what to do ... do one of you know what to do? Who to ask? Where to search? Have you had this kinda problem?
The larger question, how did 5000 Canon files get corrupted and will that happen again as the years go by (yes, i'm converting them to dng, but not so at that time) ??? i've no idea how to address. Yes, all files are backed up in triplicate but they are copies of the unopenable files - sigh ... all help appreciated.
Thank you,
Taiyo
11-28-2016 01:24 PM
The beauty of Time Machine is that it keeps old files as long as possible and then deletes old ones only as needed to make space for new ones.
11-28-2016 02:00 PM
11-29-2016 11:35 AM
are ALL files unreadable/UNopenable in ANY program, viewer, or just in PS??
a few years back I had all files stored on a windows-platform pc hard drive display as being corrupt. months later i discovered these files were NOT corrupted, when by accident I discovered those "corrupted" files were accessible via ms-dos!! i eventually moved all those"corrupt" files from the internal hard drive to an empty eHD, and they were all later viewable and usable. hope this helps
11-29-2016 12:02 PM
11-29-2016 08:31 PM
find a friend with access to windows and get into MS-Dos and see if the folders and files are there. if so, whilestill in MS-Dos, copy some test files to a eHD and see if they can be accessed in that same computer. good luck
11-30-2016 10:15 AM
There is no MS-DOS. There *is* a command prompt.
11-30-2016 10:26 AM - edited 11-30-2016 10:32 AM
thanks kvbarkley; i stand corrected!! In ALL of my references to MS-Dos above, just change that to "command prompt" 😉
11-30-2016 10:32 AM
@kvbarkley wrote:There is no MS-DOS. There *is* a command prompt.
And since the two are only superficially similar, there's no guarantee that something that once worked under MS-DOS will work under a Windows command line.
11-30-2016 10:38 AM - edited 11-30-2016 10:39 AM
I believe what has happned is that the two Operating Systems have swapped roles. MS Windows used to be an application that ran under MS-DOS. I think it began with Windows 7, the command prompt is now an application that runs under Windows.
11-30-2016 10:49 AM
Windows XP was the first NT (non-MS-DOS) based Windows for home users.
