10-30-2025
11:33 AM
11:36 AM
I'm a newbie to DPP4 and have watched a couple of tutorials but have questions about saving. I have RAW images from a Canon 5Ds.
1. When I try to exit the program it asks me if I want to save and it seems to retain changes in the RAW file format. But when I click on the actual Save button, the only options are JPEG and TIFF. Why is there that limitation on the Save button?
2. If I want these to eventually be jpegs, is the proper method to click the Save button and choose JPEG, or to do File > Convert and Save? Or is there no difference in these mechanisms? I see a lot of comments online about "properly exporting" so I want to do this correctly.
3. If there is something DPP4 can't quite do on a particular image and I want to continue to work on it in something like PhotoShop, is it better to choose TIFF on that particular image rather than JPEG?
4. The 5Ds has a 50 mp sensor so at full resolution JPEGs they end up being 25 MB. This seems high, and if I'm giving several hundred of these to my friend from her wedding, that's a significant amount of storage. I can deliver her an external drive, but is that a typical final resolution size for high quality images for printing? She's not a social media user, so I don't think she needs two versions. But she and family have said they do want some large prints. What's the best size for high resolution JPEGs for prints in this situation?
10-30-2025 11:46 AM - edited 10-30-2025 11:50 AM
1. The save on exit with DPP is saving the changed the image edit information that was applied to your RAW files. The Save button will produce the desired JPG or TIFF output from your RAW file so it is a different "save".
2. The convert and save is what is happening with the save button. When you are working with a group of files, it is MUCH more efficient to batch process the RAW files to JPG or TIFF. I use the check mark system in DPP to mark images. For example, I shot a post-season volleyball game earlier in the week and I was providing photos to both teams but some are really team specific. So I used checkmark 1 for photos for both teams, checkmark 2 for team A photos, and checkmark 3 for team B photos. Then it was easy to batch process the groups into selected directories for easy distribution by using the select only specific checkmark level in DPP.
3. TIFF provides more data than JPG so for further work, I would go with TIFF.
4. You can reduce file size by using a lower JPG quality level (set in the convert dialogue box) however if I need to downsize files I use the program IrfanView which is a freeware program that has been around for decades. It is an excellent program that handles pretty much any graphic file format and one of its options is it allows you to save a file to any smaller size selected quickly and easily. I have used it for years to downsize files and it does wonderful work of preserving quality within the limits you set. But be sure to download it from the official website instead of one of the many sites that have it for download since the others will at the least package extra junk with it and at worst you will get malware. I contribute to the author because I use it so much, there is a lot of free stuff out there but IrfanView is in a class by itself. I wish he would take on the rewrite of DPP and make it less clunky 🙂
Rodger
10-30-2025 12:10 PM
Great question as it's not overly clear what DPP does.
Hope that clears things up for you.
11-02-2025 09:42 AM
Thanks for the helpful answers!
Once I learn what the largest print size is that they might get, what is the best way of reducing the size in DPP4? Is it by using the Resize portion of Convert and Save, where I'd manually put in a different w x h in pixels? Or is it better to select something other than 10 in the Image Quality section?
wq9nsc, is there a reason you prefer IrfanView to convert to JPEG over what DPP4 will do?
11-02-2025 10:01 AM
This is what I do and not a recommendation, but i hope some of it might be helpful anyway.
If I want to do editing in another program, I save as a 16bit TIFF from DPP and edit the TIFF with the other program.
Gimp 3 free software uses a newer version of the JPEG compression algorithm and produces smaller files with higher quality than the old version in DPP. Editing the 16 bit TIFF in Gimp and in Gimp doing "export as" JPG will produce a much smaller higher quality JPEG. In gimp I select 4:4:4 for the color quantization because it adds very little to file size and increases the color quality slightly. A "quality" number in Gimp for saving JPEG of 80 might be good enough for many purposes and will make a much smaller file. The quality parameter in the original JPEG standard was 1 to 100, but in DPP it is 1 to 10. With the older JPEG algorithm, I seldom found a quality less than 90 acceptable.
I always say no to saving when exiting DPP. For the past several years, I always save a recipe dr4 file for each CR3 or CR2 file edited so that I can re-apply the same changes. Also, exiftool can display the contents of the dr4 file.
This paper describes the new algorithm version: https://arxiv.org/html/2403.18589v1 "
Source code at: https://github.com/libjxl/libjxl/tree/main/lib/jpegli
New version is in Gimp 3, but not in some other software.
11-03-2025 10:51 AM
The 1 to 10, or 12, when saving a jpg makes a higher quality image with less compression. You get a larger file size but retaining more image details. When using a lower quality setting it means more compression, creating a smaller file size but it is discarding more data. It can lead to artifacts and a loss of detail. However, the elephant in the room is that data is lost forever it can not be brought back or recovered. To make it even worse this happens every time you save the same jpg.
The good thing about DPP4 and the app I prefer, Photoshop, when saving a jpg with all the edits you might make the original raw file is not changed and all data is always safe and present.
Keep in mind even at the highest setting of 12, the jpg format is a lossy file format. So, even at quality 12, some data is still lost, and re-saving a jpg multiple times will cause further degradation. This happens even if you simply open up a jpg to view or look at it, no edits, and happen to click the 'Save' button again.
