05-11-2016 03:19 AM
Long story short, im from the States but am currently in New Zealand and about 3 weeks ago my phone (which had the Canon Camera Connect app on it) started acting up to the point where I can't use it. Anyway, I want to share my photos on my camera but it won't connect to my Nexus 7 which I downloaded the app on, but the camera is not connecting nor even acknowledgeding it. If someone could help me out it would be appreciated greatly.
05-11-2016 03:28 AM
Yes you can use it on multiple devices. You have it installed right so try this
If you have not been using the Mobile Device Connect Button or your camera does not have that button:
If you have been using the Mobile Device Connect Button to connect to your smart device:
05-11-2016 03:28 AM
05-11-2016 06:02 AM
05-11-2016 06:08 AM
LOL your welcome !
05-11-2018 03:29 PM
12-26-2020 11:24 AM - edited 12-26-2020 11:48 AM
I have an EOS R and this does not appear to work for me; camera screens are different at the Bluetooth connection point. I'd like to connect my EOS R to an Android smartphone and also an Android tablet.I can connect to an Android smartphone, but when I try to set up connection to Android tablet the "pairing" option is grayed out. Any help?
12-26-2020 03:21 PM
@Doug_E wrote:I have an EOS R and this does not appear to work for me; camera screens are different at the Bluetooth connection point. I'd like to connect my EOS R to an Android smartphone and also an Android tablet.I can connect to an Android smartphone, but when I try to set up connection to Android tablet the "pairing" option is grayed out. Any help?
Make sure every device that you connect to has its' own defined connection. To connect to a new device, you must define a new connection. Look at the connection definitions as a phone number.
12-27-2020 11:55 AM
Both the tablet and the cell have a defined connection on the camera. The only way i can figure out to switch from tablet to cell or vice versa is to turn off both the linked device (e.g., tablet) and the camera and then turn on the other linked device (e.g., cell) and the camera again. Seems like there should be a simpler way?
