08-05-2022
02:56 PM
08:32 AM
I have a PowerShot G7X Mark II. I will be taking a trip to Southern Africa (via the UK) next year - how do I handle my battery charger outside of the US? Is there some sort of adapter I should use? Thank you.
08-06-2022 12:18 AM
Hi parawen,
To use your charger in a different country we recommend getting a plug adapter to match the type of power outlet used there. Do not get an adapter that converts or adds charge because that can over power the battery and damage it. The adapter should just adapt the charger's plug without changing any charge. We do not make power plug adapters through Canon, so there aren't specific ones that we can recommend.
08-06-2022 12:18 AM
Hi parawen,
08-08-2022 07:06 AM - edited 08-09-2022 01:02 AM
This works really well for us, thank you! Facing same issue here. Help is appreciated. CredibleBH Login
07-14-2023 03:01 AM
Thanks For Sharing Very Useful Information.. Nice Blog.. CredibleBH
