11-02-2023 01:35 AM
11-02-2023 11:58 AM - edited 11-02-2023 12:20 PM
The old Arc Form Drive EF 28mm f/2.8 and EF 35mm f/2 both use the EW-65. The ES-65 is only a little longer, and would probably also work. Especially if you are using it on a crop camera.
The EF 28-80mm f/3.5-5.6 USM (Mark I metal mount) uses the EW-68B, but the EW-68A is nearly identical, and will also fit.
The EF 35-135mm f/4-5.6 USM uses the EW-62
The EF 70-210mm USM and EF 100-300mm USM are nearly identical and both use the ET-65
11-02-2023 11:21 AM
EF 28mm F/2.8 AFD: EW-65II
EF 35-135mm F/4-5.6 USM: EW-62
11-03-2023 01:04 AM
Hi Mike,
Wow, thank you so much for the detailed information! All of my lenses are usually fitted to my 5D Classic, but I sometimes use a Rebel XT as well.
