08-19-2015 06:55 AM
08-19-2015 11:26 PM
I'm not sure whether or not this will help as it is for a different camera but it may be worth a shot:
"Charging method of the internal rechargeable backup battery
09-03-2015 01:45 PM
Thanks for the suggestion. Unfortunatly nothing works. According to my XF100 manual, you connect the AC power to it to power it for at least 24 hours with the XF100 off. I've contacted Canon about the issue and will bet I have to send it in!!
Thanks again
James
01-23-2016 02:09 PM
James, did you ever get a reply from Canon? Please post.
01-25-2016 08:50 PM
I did receive an answer, but not one I was happy with. My post and the reply is just above this one in the queue.
01-26-2016 04:36 PM
I did receive an answer from Canon Tech. They told me to call Parts which I have not done yet. I belive that is not the right answer, According to web searches, the battery is "soldered" in and probably has to be replaced by Canon. I'm going contact Canon Tech again and see if they give the same answer.
James
01-26-2016 07:43 PM
Thanks.
While I didn't get the answer I hoped for, I believe that what they said sounds right, and it tracks to what you heard.
I'm not about to pay the repair charge for what is really a minor inconvenience. I have another battery. I just need to swap quickly before the memory dumps, and the existing battery is keeping the memory alive for a while.
Let me know if you hear something different.
Jim
