New XF-200 low-noise setting
bwaltz
I just upgraded my XF-200 to the latest firmware. The press releases indicate a new low-noise feature. I have looked and don't see how to activate it. Where do I find that on the camera's menu. Is it simply the noise reduction options in the custom profiles?
Mykolas
Hi bwaltz!
Welcome to the Canon Forum!
A new Custom Picture setting was added [C8: S/N Pri].  This preset give priority to the image's signal to noise ratio.
5 REPLIES 5
Mykolas
Hi bwaltz!
I actually discovered this last night and tested it. It works very well in low light, immediately apparent, and much better than the low-noise options in the Custom Profiles. Those tend to produce a fuzzy picture toward the upper end of the range. In contrast, the S/N option held a good bit of detail only w/o the noise. Thanks for responding to my question.
kenfe
halo bwaltz and evryone that helping!
i need help
i just bought canon xf200 and i would like to use noise reduction in menu but i coudnot!
kenfe
pls help me i have to film an event day after tomaorow!
You need to look for the Custom Picture option (it was mentioned in a previous post).  Instructions can be found starting on page 132 of the User Manual.  Also look at page 138 for a description of the Noise Reduction settings.
Friends and Family
