RC-IP1000 Stick Drift
ambuehlance
Hey all,
I’m on a show setting up the RC-IP1000 PTC controller with two CR-N500s and the are constantly panning to the left. If I pan the joystick to the right it goes but the second I let go it pans to the left again. If I switch from Camera 1 to control Camera 2, 1 will stop panning and 2 will start. Is there a way to re-calibrate the joystick on the controller? I cannot figure this out.
Thanks
#RC-IP1000
3 REPLIES 3
ambuehlance
Fixed it by power cycling the controller, but if someone can answer the joystick calibration question that would be great!
Based upon your description it sounds like a controller issue or a controller/camera communications issue, not an issue with either camera.
Have you watched the Canon instructional video at https://www.youtube.com/watch?v=klGKQbzkRNg ?
 An AI search turned up the following potential issues:
  • The control transmission contains corrupted data.
  • The control wire is too long, has lost integrity, exhibits Crosstalk.
  • Data lines to the cameras have ground faults on them.
Two of those three involve cabling issues.  You would need to share a few more details regarding your cabling configuration, including lengths, to assist in diagnosis.  I am not familiar with the unit and see it runs on 12v and Power over Ethernet.  If you could provide that information it might help, as well.  I know some devices are underpowered when run over just Power over Ethernet (PoE)
Plus>> Canon imagePROGRAF PRO-1100 Printer. My photos are edited using Canon Photo Professional and no Adobe products.
Join esteemed Video Production & Live-streaming Specialist, Rowan Johnson, from Southpoint Films, as we embark on an in-depth exploration of initiating your journey with Canon's PTZ cameras and controllers. 00:00 - Introduction 02:01 - Chapter 1 - PTZ Range Overview 04:00 - Chapter 2 - Things you
in addition I think you should reach out to Canon support.  This number is specific for PTZ cameras, including CN-500's
1-800-423-5367 Monday through Friday 9:00 to 6:00 EST
I suspect they will have more information about calibrating the controller when used with these cameras.
