12-01-2021 06:25 PM
After several years of use I was recording a MP4 video and when I went to replay it had a "?" mark where the video should have been and said it cannot play back.. Any suggestions would be greatly appreciated
12-02-2021 04:00 PM
It's likely that the clip has become corrupted. This can occur if the camera is shut off or loses power while still trying to record. Or, the memory card has gone bad.
Sometimes the camera can try to repair the file, but it sounds like it cannot in this case. About the only thing I can recommend is copy the file to your computer and see if any parts of the file is salvagable. If it was really crucial footage, could also look at data recovery services.
12-02-2021 04:00 PM
12-04-2021 10:39 AM
Ricky,
Thank you for the advice as I am going to start by replacing the SD card.
Steve
