11-27-2021 03:31 PM
Hi, I am new to the community so this may have been answered before (please forgive me if it has). I see in the instruction manual for the XA40 a table that shows the approximate recording times for 8 GB, 16 GB, 32 GB, 64 GB & 128 GB SD cards. Will the camera recognize and record on larger capacity cards such as 256 GB & 512 GB or even 1 TB ? Being able to use larger capacity cards would mean less card swapping for even longer recordings. Thanks for any and all the help concerning this question.
12-02-2021 04:04 PM
It should, at least the 256 GB variants. The main thing is that you'll want to ensure you use the correct cards (e.g. I think the XA40 would require UHS-I cards and not work with UHS-II cards.
Having said that, do you really anticipate capturing continuous footage that would required 512 or larger cards? I didn't think that the codecs on the XA40 were that hungry for space.
12-02-2021 04:27 PM
Thanks Ricky. New to the camera and was just asking because I will be attending a wedding soon and just wanted to have enough memory before hand to ensure I can capture all of the excitement ! I have (2) 128 GB, (2) 256 GB & (2) 512 BG cards. Was just making sure I would not have to do a lot of swapping them out and in. I always figured the bigger the better so there will be less chance of missing any action.
