12-15-2018 04:35 AM
12-17-2018 08:49 AM
Hi Rislo,
Please follow the steps below to disable the wireless direct setting:
Select
Setup on the HOME screen.
Select
Settings.
Select
Device settings.
Select LAN settings.
Select Wireless Direct.
Select Wireless Direct active/inactive.
Select OFF
12-17-2018 08:51 AM
12-15-2018 10:05 AM
3446
Cause
IP address and subnet mask are conflicting.
What to Do
Select OK on the printer's touch screen.
Disable the wireless direct or change the wireless LAN network configuration. When changing the network configuration, specify a unique subnet range for each of the wireless direct and the wireless LAN to prevent a conflict.
For details on changing the network configuration, refer to the documentation for your wireless LAN router.
Press this button. What does it say? Are you connected to your wireless network? If not are you able to select the SSID name and enter your password? Keep in mind the printer only supports 2.4Ghz broadcast so thats the network you'll need to connect to.
There is nothing magic about Wireless Direct Printing, so I'd disable it. You can print from any device, mobile, laptop or desktop connected to the same wireless network anyway.
Please post your progress.
12-15-2018 12:52 PM
12-17-2018 08:49 AM
Hi Rislo,
Select
Select
Settings.
Select
Device settings.
Select OFF
12-17-2018 08:51 AM
