PIXMA TR4720 error code 5100
LadyBello2004
1 REPLY 1
Anonymous
Not applicable
Error code 5100 on your Canon Pixma TR4720 typically indicates a problem with the print head or ink system. Try checking for any obstructions, ensuring the ink cartridges are properly installed, and performing a printer reset.
Understanding Error Code 5100 for Canon Pixma TR4720
Error code 5100 on your Canon Pixma TR4720 typically indicates a problem with the print head or the ink system. This error can arise from several issues, including:
Common Causes
  • Print Head Misalignment: The print head may not be seated correctly.
  • Obstruction: There could be foreign objects blocking the print head.
  • Ink Cartridge Issues: Low or improperly installed ink cartridges can trigger this error.
Troubleshooting Steps
Step-by-Step Solutions
  1. Check the Print Head:
    • Turn off the printer and unplug it.
    • Open the printer cover and check if the print head is properly seated.
    • Gently remove and reinstall the print head.
  2. Inspect for Obstructions:
    • Look for any paper scraps or debris inside the printer that may be blocking the print head.
    • Clean the area around the print head carefully.
  3. Examine Ink Cartridges:
    • Ensure that all ink cartridges are installed correctly and have sufficient ink.
    • Replace any cartridges that are low or empty.
  4. Reset the Printer:
    • After checking the above, plug the printer back in and turn it on.
    • If the error persists, perform a factory reset if possible.
If these steps do not resolve the issue, consider contacting Canon support for further assistance.
