12-11-2016 05:16 PM
I'm trying to log into the printer using a web page. Can anyone tell me what the default username and password for the MX350 series printer might be?
12-13-2016 12:04 PM
Hi drniemczycki.
The username will be (in lower case):
canon
and the password will be:
ADMIN
If ADMIN does not work, please use the serial number of your PIXMA MX350 as the password.
12-13-2016 12:04 PM
Hi drniemczycki.
canon
ADMIN
07-03-2020 09:22 AM
YOUR REPLY DOES NOT WORK
07-06-2020 02:02 PM
Hi milvet,
If that did not work for use, the password may have been changed. The only way to resolve this would be to reset the printer settings back to the default values.
To do this, please follow these steps:
1. Press the Setup button on your PIXMA MX350.
2. Select Device settings and press OK.
3. Select LAN settings and press OK.
4. Reset LAN settings and press OK.
You will have to reconnect your PIXMA MX350 to your wireless network after this is complete.
03-12-2022 06:59 PM
Hello, I am having problems
with my MX350, we can’t find the pass phrase
