01-02-2026 09:47 AM
under /sendsupport_login.html email settings
the email is set to [email protected]
password is set to the App password set in 365
SMTP server is set to smtp.office365.com
under TX setting for email settings all the same settings are set and the SMTP server connection says successful
however when we go to scan to email on the printer is gives and error 806
01-02-2026 09:51 AM
Thanks for joining the conversation, Jframpton!
So that the Community can help you better, we need to know exactly which Canon printer model you're using within the MF750 series. The model number should appear on the front of the unit at the lower right. That, and any other details you'd like to give will help the Community better understand your issue!
Thanks and have a great day!
01-02-2026 10:28 AM
I'll try to look into this further later this morning. The 806 error typically indicates a bad username or password.
Can you please confirm the model of your device as @Danny requested?
Is this a US model or i-Sensys (750 Series) We need the actual model # 😉
All of my lasers are first gen, They do not support modern auth. Recently Microsoft has been deprecating support and requiring modern auth for 365. I've been following but not closely.
I'm using gmail for SMTP on my devices with an App Password. I'll do a little more digging once you reply.
01-02-2026 10:32 AM
I also just updated the FW on my 656, but modern auth is not present. Canon is starting to release mkII's of their lasers. I'll need to do some additional research.
