12-13-2022
10:08 AM
12:53 PM
I have a Neewer PY-16 Transmitter that fires my flash but I can't workout how to set the camera to fire the transmitter It has a centre pin that connects to the hotshot. I can test fire the flash using the test button on the transmitter.
If anybody can assist it would be appreciated
12-13-2022 11:54 AM
What camera? But off lacks the center pin on the hotshot, you can't fire the flash from this camera.
12-13-2022 12:45 PM
The camera is a 70D Canon
12-13-2022 04:17 PM
what is a Neewer PY-16? The Neewer website doesn’t recognize that product name.
12-13-2022 08:00 PM - edited 12-13-2022 08:04 PM
Are you using LiveView? If so, you must go into the menu and disable Silent LiveView shooting. 3rd party, non-ETTL flash units and triggers (with only one pin) will not fire in LiveView if Silent mode 1 or mode 2 is enabled.
If you are not shooting in LiveView, then there must be a problem with your Neewer trigger.
09-03-2024 05:36 PM - edited 09-03-2024 05:37 PM
Thanks! This live view fix did the trick for me!
