Speedlite Transmitter ST-E10 Compatibility
pieshi
Will the ST-E10 work with my 430ex ii and EOS R?
kvbarkley
The ST-E10 is RF only, so it will not work with the 430EX-II
6 REPLIES 6
jrhoffman75
The ST-E10 requires the new Canon multifunction hot shoe and a flash with radio (RT) versions.
If your gear meets these requirements you are good to go.
kvbarkley
JoeySnaps
Enthusiast
It also won't work with the EOS R either, because the R doesn't have a new multi-function shoe to match the multi-function foot of the ST-E10.
It won't work with the 430 EX II because that flash supports optical off-camera control only, while the ST-E10 supports RF radio but not optical.
So, sadly, the answer is No. The ST-E2, if you can find one (maybe used on Ebay?) would do the job for you, though.
R6mkII, various lenses, speedlites. Also legacy Canons going back to T90 and even A1.
AmmyP
Well, it certainly does not with an R5C and EL-1 combo. Come on Canon...?
p4pictures
EOS R has the regular old-style hotshoe with five contact pins. The best inexpensive optical sender unit that fits the EOS R is the EL-100. With EL-100 on the EOS R, set it to Sender mode and then set the Speedlite 430EX II to slave mode (now referred to as receiver mode).
An EL-100 on the camera can be set to be included as part of the exposure or only send optical control signals - in the form of flashes a few milliseconds before the shot is taken.
Brian
I second this. The ST-E10 doesn't work with the R5c. I tried updating the firmware from 1.1.0 to 1.2.0 in video mode, but it gave me an error, and now it doesn't recognize it at all.
