04-02-2026 08:01 PM
I attempted to use the Speedlite Transmitter ST-E10 with the Canon R5c, but unfortunately, it didn’t function as expected. The ST-E10 fails to communicate with the R5c in photo mode, although it is recognized as an accessory in video mode. I specifically need it for photography, not for video work. I also tried to update the firmware from 1.1.0 to 1.2.0 in video mode, but I ran into an error that halted the process. Now, the R5c no longer recognizes the ST-E10 in any mode. When I turn on the R5c in video mode, the ST-E10 blinks twice, which likely signals a failure or firmware mismatch. In photo mode, the R5c still does not acknowledge the ST-E10 at all. It's extremely frustrating that I can't use this accessory as intended in photo mode. I strongly urge Canon to address this issue in the next firmware update to enhance user experience.
Thank you for your time.
04-02-2026 08:23 PM
@thefunkmobile The EOS R5 C is NOT COMPATIBLE with multi function hot shoe flashes or transmitters. Look into the ST-E3-RT or older EX series speedlites.
04-02-2026 08:23 PM
04-03-2026 09:55 AM
What my colleague @deebatman316 has mentioned is correct.
I see you've already found an older thread about this topic.
04-03-2026 03:00 PM
Thank you all! I just returned the ST-E10. It’s unfortunate that it’s not compatible but I already own the ST-E3-RT and was just hoping for something smaller.
