Speedlite EL-5 won't connect to Godox X3 trigger
JovanJoseph
I have purchased a speedlite flash EL5 and Godox trigger x3 I cannot connect it. Could anyone guide me how to do it please.
3 REPLIES 3
Isskariot
Hello, do you find the answer? I have the same problem
Godox and Canon speedlites ARE NOT cross compatible. They use different communication.
-Demetrius
Bodies: EOS 40D & EOS 5D Mark IV
Lenses: EF Holy Trinity, EF 50mm F/1.8 STM, EF 70-210mm F/4 & EF 85mm F/1.8 USM
p4pictures
Probably the least expensive route to get this to work is to get either the Speedlite Transmitter ST-E10 for your camera or get a Godox Speedlite.
You have two devices that communicate over radio even using the same frequency, but one uses "Godox language", the other uses "Canon language". It would be like an Italian trying to communicate with a Finn - they can both speak, but neither will understand the other. While the Godox trigger might be the Canon version, that only deals with how it communicates with the camera, not how it communicates with the flash.
Brian
