06-14-2024
05:45 AM
08:19 AM
Hello guys
I’ve just read manual for R50. Here is a wireless flash mode in menu. What does it mean? Can I use any EX speedlite without multifunction shoe but with radio slave mode in TTL mode? I have 600EX II RT and 430EX III RT. I wish I could use them in shoe of R50 without AD-E1.
06-14-2024 01:57 PM
There is no RT system radio transmitter in the EOS R50 camera. You cannot mount the 430EX III-RT or 600EX II-RT on the camera as there are no connections for the hotshoe of the flash. You would have to use the AD-E1 adapter, it converts the 21-pins of the multifunction accessory shoe to the older layout that the Speedlite 430EX III-RT or Speedlite 600EX II-RT has.
A better solution is to get the Speedlite Transmitter ST-E10, this has a multifunction hotshoe connection and will fit directly on the EOS R50. The ST-E10 is a radio transmitter module that will happily work with your existing Speedlite 430EX III-RT and Speedlite 600EX-RT. I have the same Speedlites and picked up the ST-E10 to remote control them a two separate off-camera units.
Then the EOS R50 camera menu becomes the way to set the functions of the ST-E10. It provides the same E-TTL / M / Group modes as the Speedlite 430EX III-RT, plus second curtain and high speed sync. On the ST-E10 is a MENU button, that when pressed instantly calls up the Speedlite settings screen on the camera.
06-14-2024 09:31 AM
You can use radio or optical wireless flash so that you can control your other two flashes off camera, no hot shoe required.
06-14-2024 10:39 AM
Thank you for reply! I am so sorry, but it is not clear for me. I am just thinking over purchasing R50 and compatibility of EX speedlite is a major point. Is the camera included its own radio module on board? Or “wireless” menu in camera just duplicates functionality of supported Canon RT accessories? I want 430EX III to be installed on the camera but to be operated by radio due to incompatibility of the camera shoe
06-14-2024 01:57 PM
06-14-2024 02:38 PM
As usual, you are correct. I got confused between the "Internal flash function settings" and the "external flash function settings". Sigh.
06-14-2024 03:03 PM
Thank you! Your answer is irrefragable. Best regards 🤝
08-20-2024 03:05 AM
Hi Brian,
I am using a Godox X3 TTL trigger with twin flash. I am unable to connect it to the camera, could it be the same explanation as above? Would using AD-E1 adapter solve the issue?
Thank you,
Darshika
08-20-2024 03:45 AM
The EOS R50 only has the 21-pins at the front of the hotshoe, none of the five legacy connections needed by most flashes and triggers. The AD-E1 adapter connects to the 21-pins and converts them to provide the standard five pins required for your trigger.
08-20-2024 03:46 AM
Thank you Brian, much appreciated!
