03-16-2020 06:09 AM
Thinking about getting a second-hand Canon Speedlite 420EX for my Canon 250d. How do I know if it'll be compatible as the 420EX is a much older model and the 250d doesn't have the central metal contact point on the hot shoe? I've been told that the updated (and much worse) mount works with all Canon speedlites, but how can I be sure?
03-16-2020 09:58 AM
The product manual discusses feature support
Type A vs Type B cameras.
Yours is Type B "TTL"
So read pages 9 to 16, and 31 to 53
http://downloads.canon.com/camera/flash/Speedlite_420EX_manual.pdf
~R5 C (1.1.2.1), ~RF Trinity, ~RF 100 Macro, ~RF 100~400, ~RF 100~500, ~RF 200-800 +RF 1.4x TC, BG-R10, 430EX III-RT ~DxO PhotoLab Elite ~DaVinci Resolve Studio ~ImageClass MF644Cdw MF656Cdw ~Pixel 10 ~CarePaks Are Worth It
03-16-2020 01:41 PM - edited 03-16-2020 02:13 PM
06-28-2020 02:51 AM - edited 06-28-2020 02:53 AM
Martin, I have the other "crippled Canon", the Rebel T7, which is also missing the center x-sync terminal on its hot shoe.
However the 420EX flash I got for $21 on eBay works perfectly on it. It's my first E-TTL flash and I'm amazed at the beautiful exposures it gives, even in bounce mode.
06-28-2020 12:45 PM
@Quiet wrote:Martin, I have the other "crippled Canon", the Rebel T7, which is also missing the center x-sync terminal on its hot shoe.
I would guess that it's "especially in bounce mode". E-TTL flashes are strongly biased for use as fill flashes, which is fine if that's what you need but not always so fine otherwise. But bounce flash effectively kills the fill-flash bias and provides proper lighting for the overall (indoor) scene. That's an oversimplification, of course, but this isn't the time or place for a detailed lecture on flash technology (even if I were qualified to deliver it, which I'm not). Suffice it to say that E-TTL flashes generally perform admirably as bounce flashes. At least that has been my experience.
06-28-2020 05:16 PM
Quite right, Bob. I guess I do always use bounce when possible and cringe a little when forced to use direct flash.
I've always despised direct flash, thought E-TTL is the least offender.
05-17-2022 04:22 PM
Former newspaper photo journalist here. We used to use direct flash all the time with film chrome and negatives. It was Colorado so always sunny and fill was needed on chrome films. The trick was to dial down the flash -1&3/4 stops at 1/250th f8 rear curtain sync and the fill worked great.
Fast forward to the digital era and, If I am not bouncing like you do, I have the flash dialed down at least -1 stop. I dont like having to control the flash thru the camera. And the flash does a preflash that bugs me. But that 1 stop back off still works.
