One 600EX-RT added a 600EX II-RT flash firing 1 sec apart not together when triggered by ST-E3-RT
spockeac
Slave 600EX-RT set to CH A and slave 600EX II-RT set to CH B when triggered by Master ST-E3-RT. Flash CH A fires first then 1 sec. later CH B fires. can not get then to fire together. ST-E3-RT not connected to camera.
How do fix to fire together or maybe it is user error.
5 REPLIES 5
rs-eos
How is the ST-E3-RT the master if not on the camera?   Since both versions of the 600 series can use radio wireless, why not have the ST-E3-RT on your camera?  You can then have both flashes in the same group.  Or in different groups if you'd like to control them independently.
Ricky
Thank you for your input. The ST-E3-RT is on the camera. Taken off for testing. When in the same group the both fire as expected, together. I do not understand why in different groups, the A group fires and the B group delays fire for about a sec.
What settings do you have in each group?  Perhaps one is set to first curtain and the other to second curtain?
Ricky
Thank you for your input. I do not see on the screen a way to set up first and second curtains. I do not know what that even means. Also, I would have had to do this on both speedlites. When I switch the speedlites making the other A and the other B the effect of the delay is the same. The B group is delayed by 1 sec. All on screen information between the 2 speedlites looks the same.
p4pictures
If you are pressing the test button on the ST-E3-RT, then the expected behaviour is to trigger each group in sequence. Te idea being that you can see if a specific group is triggered or not. It was more of a problem when using optical wireless, but the behaviour is the same when pressing the test button when using radio.
If you are using E-TTL, the way the system works is to get each group of lights to send out a pre-flash, so with two groups there would be two pre-flashes. Then the camera looks at the pre-flash metered results for each group and works out the appropriate power for A and B groups, then instructs both groups to fire at the correct power when the shutter is open.
Brian
